Stylin55_oh
Hey guys,
I'm officially calling today day 1 of the 3L build on the 98.5 black svt i picked up with no motor. It's day 1 because i bought a 04 taurus 3L with 26,000mi. This install will be a full 3L install. No hybrid, no porting, just a stock 3L going into an svt. I will upload pictures as i go. I have already purchased headers and a y-pipe. This is my to do/buy list. any input as to what im missing would be greatly appreciated.
parts i need:
Exhaust manifold gaskets - $12ea. - XW4Z-9448-AA
MIL delete -?
high flow cat -?
cat back exhaust - ?
oil seal front timing cover - $8 - BCA part# 482041N
valve cover seal - ? - ?
parts i might need:
Cougar motor mount - $33 - 1S7Z-3A732-AA
new oil pan (escape?) - $110 - 3M4Z-6675-BA
new oil pickup - $35 - YL8Z-6622-BA
timing cover gaskets - $5ea. - F5RZ-6020-A,B,C
2.5L timing cover (since i only have parts of the old 2.5L i may not have one)
2.5L crank pulley
oval port injector connectors - $69
Parts not specific to the 3L but a good idea to replace:
lower control arms
brake pads
rotors
tie rod ends
struts
springs
waterpump (metal impeller) (2.5L)
things i need to do:
Trim alternator brackets
modify fuel rail (not sure if i have to)
use the 2.5L timing cover (change pulse wheel to 2.5 since I'm using a 2.5L computer)
remove pilot bearing off of crankshaft
get a tune after the car is together and running.
Transmission:
new Luk clutch - $210 - 07-137
ford slave cylinder (luk comes with one but ive been told its best to buy a new one from ford)
resurface the flywheel - $50
Rebuild & add torsen
i am referencing http://www.contour.org/ceg-vb/showthread.php?t=9272
i also have an 01 cougar shift tower that I could use but i would need to buy the cougar shift cable clamps, i am not sure if the cougar tower is an upgrade. I am sure it is, but i honestly dont know.
parts i need:
MIL delete -?
high flow cat -?
parts i might need:
2.5L crank pulley
lower control arms
brake pads
rotors
tie rod ends
struts
springs
Transmission:
