dlphnfn
With the 2 header group buys going on with *great* deals, I'm contemplating both. I've googled the difference between the two types, and it seems that the consensus is that stainless is prettier and basically lasts forever, steel requires a coating so it doesn't rust out and it will chip and rust sometime in its life if it's used heavily (dd). Temps can get hot enough to flake some coatings too (or so I read).
My car is getting to be more and more of a garage queen, so I don't care about use. I do like the look of stainless, but you can't see it anyway. :crazy:
What are pros and cons of each system? Which one is a "best buy" if they are the same price? (Damn close to that now!) Are there any differences in sound? I'm guessing not much if any.
Given the 2 "as they sit" I'm leaning toward Racebits because of the Y Pipe having a nice rounded turn.
Racebits - Stainless :drool:, better (?) turn in the Y, $400 to your doorstep, but you need to add O2 bung.
MSDS - tried and true! , slightly cheaper, $380 to your doorstep, but it has that ugly turn in the Y (which I'm not even sure if it's an actual "problem").
Erick --
Erick --
