cobrawannabe
Addicted CEG'er
BEFORE WE BEGIN...
I am asking the community to keep things civil in here. If you do not like this style of vehicular modification, keep your mouth shut. This thread is for those of us who do. This thread is intended to help CEGers find the perfect balance of form and function in a manner we all like. Do not come in here only to bash the "hellamadflushyodiggitydawg" style. No, Contours are not VWs, and we do not wish they were; we just like the style.
Now that that's out of the way, let's get down to business.
I have noticed an influx of members from CEG joining FocalJet. This could be due to many reasons, but I have noticed that a number of us join to post in [FJ]'s suspension section. I'm sure many of you have noticed the wealth of knowledge on the site regarding wheel offset, fitment, and suspension adjustment in accordance to them. This thread is designed to make your life easier in the search for this information.
If you have any questions regarding this topic, feel free to ask. If I can't answer, I'm sure others will fill in. Let's use this thread to work off of each other's knowledge, rather than bicker about things we all know.
Basic Rumors Dispelled:
There are a lot of popular beliefs on this site (just like any forum) that are taken as absolute truths which may or may not be so true in every case. Let's take a look at them and discuss why this may be.
Wheel Spacers are Not a Death Sentence
While they may not be ideal, wheel spacers are an easy, safe way to flush a set of wheels which need that extra outward push. The general belief here is that a wheel spacer of almost any size will destroy the wheel bearings in a Contour. This is simply not true. While they are not the toughest bearing on the planet, CDW27 wheel bearings are not made of glass and hammers; heck, all four of mine went 165K without being replaced! A small spacer will not ruin them. Let's look at the actual effect of a wheel spacer.
First, we must compare the offset of two popular wheel choices for Contours:
1. Focus SVT 5-spoke
Offset: 49mm
2. OZ Ultraleggera
Offset: 42mm
There is a difference in offset between the two wheels of 7mm. This is normally not even a consideration when purchasing the OZs because, well, TireRack says they fit. This is not in any way an incorrect assumption.
Now, when a Contour driver decides, instead, to go with the Focus wheel; they notice quite a bit of space between the fender lip and wheel face. This, in the scene, is called "sunk", since the wheels appear to be sunk into the fender. The common solution would be to add a 5 or 10mm spacer behind the FSVT wheels to get rid of that gap, and "flush them out". This is where a lot of us pause, and think of the extra stress the spacers will put on our wheel bearings. What many of us do not realize is that the spacers have the VERY SAME effect on bearing leverage as a wheel of lower offset. This principle is good to live by, as long as you don't go nuts with spacers. Remember, the thicker your spacers are, the longer your studs need to be. This is not so much the case with lower offset wheels, as the lug seat can just be drilled deeper into the face of the wheel, moving the pressure point farther inward.
I need to go to class soon, so I will stop here, for now. Check for additions later on.
Offset: 49mm
2. OZ Ultraleggera
Offset: 42mm
