Recoveryone
Thats a bit of a stretch,  bass sounds are movement of air = sonic/seismic motion.  Now with that cover,  an 6.5" cone can not move as much air as a 18" cone.  Now the voice coil at the bottom of the cone is the real player here. So when it comes to subs the longer or even better a dual voice coil is best in a sub design.   A box/ housed enclosure helps a sub reach deeper sounds through port tunning while using less power to push the sub driver itself.  So if you used a reference track (test tones) to test ur system you would see that a 6.5 sub driver would not be able to keep up with a 18" sub if the designs where the same (voice coil, wattage capacity).
