muntus
Mine goes all the way up to eleven.
			There really isn't that much trunk rattle. The rattling that you get will come from the third brake light, and maybe from your license plate. I have had to replace 5 C74 bulbs in the third brake light since I've had subs...Many people custom cut a rag and shove it under the housing for the bulbs/circuit board. I tried doing this but it didn't help, because my problem isn't the housing vibrating, but the whole circuit board instead! So far I haven't devised a way to keep the circuit board from rattling, but it doesn't do it all the time so I don't mind too much...
i dont know about your system but my trunk rattles like a tin can, even with 3 layers of sound deadening on it, my rear deck was even worse till i put 10 layers of second skin on it and screwed it down.
alright well i have a dumb question. my speakers buzz with bass when i turn em up to loud. if i put subs in does that mean the door speakers wont be doin bass anymore or what. how does the sub work basically.
TS-a6881rwhat is the model number on those Pioneers
You obviously hooked something up wrong, because there is no way that a factory speaker beats an aftermarket one unless you have a BOSE, Infinity, or Rockford Fosgate premium system from the factory... In those cases I can see the factory speakers being better than aftermarket...
Ford never used Infinity speakers, did they? :shrug: I know some older ones used JBL's. Maybe they were replaced at some point by a previous owner.
TS-a6881r
at the beginning you'll see i said "make sure you don't have the premium infinities" as the ones that were in my car were infinity, and they sounded much better than the pioneers. now they may be aftermarket, but they look pretty aged and I thought those were the speakers you got with the premium sound package from ford?
I have four of those Pioneers (doors) in my ride and I have never looked back. But again it all goes on how your system was set up and how your bass is being managed. I run 2 alpine amps, (1) four channel runs the Pioneers and I have (2nd) mono amp connected to my subs and have the cross over set to only handle the deep bass, bridge off amp (1).
:nonono:
you can get enough bass from 1 12" if you know what your doing.
that's why the sarcasm meter was a 10 afterward. and i don't care what 12 you are running, it wouldnt touch 2 18's. Then again, who needs 18's?
Please tell me you're kidding? No one can be that ignorant.Put up 2 18" Pyles with a good 1200WRMS, they'll pop. Put up 2 8" 1508's from Digital Designs with a good 1500WRMS, and they'll handle it, and beat the 18's like the
es they are.
Put up those 2 18's against a DD 9512, and you're getting laughed at.
MRP-F450 + MRP-M850??
Personally I would like a setup of an in dash MV that had separate Pre-outs for F, R, an SW, a 4-channel for interiors and an amp for sub. My ideal setup would be a box non ported with 3 - 10" subs of decent power handling, my setup I'm going for soon will be 3 rockford fosgate P3 10" 4ohm DVCs with a kenwood kac-9103D to power them does 500w x 1 @ 4 ohm, 900w x 1 @ 2ohm, and 900+ x1 @ 1ohm stable.
es they are.
