ikaika808
I have found a set of rims that are 17x8 with an ET 19... Does any one know what I would have to do to make the rims fit with no problems on my 2000 CSVT...??? Thanks in advance... Roland / Ikaika808
....must......resist............urge.........to troll....
Buy a wheel that fits with an offset between +42 and +49, throw a 215/45/17 on it like everyone else and be done.
Nahhh, screw it. Poke like crazy, throw a 195 tire on it and stretch, or if you're super ballsy, do a 185, and pull the piss or radius your rear fender.
I'm being resurrected from the dead just to chime in here.. the OP, with some math done here, and using my previous wheel and tire setup, could essentially run a 17x8 +19 with a 195/45/17 tire.
Also, when you lower these cars, it adds negative camber, especially if he's gonne run B&G Autobahn springs (IIRC it lower's the car like 2 or 2.2 inches).
With saying that, you'd probably wanna pull the splash guards, flare the fenders. Also, making the dampers stiffer wont affect length of suspension travel.. he could run on full soft and still rub, or not rub, as much as full stiff on Koni's. The stiffness of the springs will affect that aspect... would be nice to know what the spring rates of the Autobahn springs are..... I could keep going on but i'll stop haha.
