sportracer
quick question, I know this is not the thread but I don't want to create a new thread since I only need 1 answer.
So would it be illegal or too bright if I remove the tab on the low beam or if I drill a hole through the tab.
You would not get the same effect, that is there to disperse the light to give you a wide band on the road. If you took it off you would probably get a narrow beam and would be worse for seeing.
