can only afford to fill up with 87... ....uses only about 10 gallons.
For the same $2.00 savings you could increase your tire pressures to improve mileage and STILL see the SAME MILEAGE AS WITH 87 (or even better, since it is TUNED for premium)
That is $2 that I really need in my pocket rather than in my tank as well! In CT, you can get a ticket and fined for having overinflated tires; that and higher than recommended pressures become dangerous and will wear much faster than a properly inflated tire.
435 to a tank:shocked: wow!I'm really pleased with my gas mileage even considering I just rolled 154k. I got (even though i cut off pulling in, and changed the fuel filter after) about 435 off a full tank of 93. I baby my car.
I 've taken to coasting down long hills in neutral, but haven't noticed my overall mpg going up.
do the cylinders continue to receive spark?
If it is a long big hill, just engine brake down it to shut off your injectors instead of idling. I engine brake all the time to save gas and it really makes a difference. When idling in neutral down a large hill or moutain you are still sipping a good bit of gas and possibly having to ride the brakes as well. Instead, just throw it in gear and engine brake so your injectors stop spraying all together!
On a big long downhill, I get over 300 mpg when I shift into neutral, compared to about 80 or 90 mpg when I leave it in gear.
