Oct., Nov., Dec FS/WTB Thread...
wtb:want to buy
wtb:want to buy
Hi im wanting to buy the interio light panel that goes into the sunroof motor cover for the 1999 csvt. My panel is gray but I am not picky about the color. Please pm me with any for sale or if you know anyone that has one for sale. Thanks for all the help.
F/S Midnight Blue Interior (Pick up only) Orlando, FL
Selling an almost complete set of MNB interior.
Both Front seats
Full Rear Seats
4 Door Panels
Seat belt pillars
All power window/lock switch
Center console
Everything is in pretty good condition and to check out the pictures, go to craigslist:
http://orlando.craigslist.org/pts/2501057433.html
I was goona swap into my 99 T-Red but the tan is growing on me now. PM me if anything.
Selling car in the Central FL area
http://www.contour.org/ceg-vb/showt...VT-black-mid-blue-full-MPV-3L-swap#post941654
just figured i would post it in here too since it's a local sale. im thinking my new ish 04 mustang will be replacing this car ..
For Sale:
For Sale:
I found a decent passenger side headlight at a local JY. It has some scuffing on it, looks like water got into it at some point so that will need to be cleaned somehow. Also bugs started trying to nest in it.
Then I also have a Black jack point cover. Tabs are good on headlight and JPC. Pm offers or for pictures!
SOLD!
I need to find some new sideskirts! I dont care what color they are, just as long as they are in 1 piece. They do not have to be perfect by any means. I am trying to get a jump on getting my car ready for spring zing!
Someone shoot me a price + shipping!
I've got a few parts for sale.
99 SVT lower intake injectors and fuel rail
I don't know why this thing has blue injectors
Mount pass side
I've got a few front roll restrictors with brackets
98 svt upper intake
PC'ed 98 SVT upper intake
Damn this thread's title needs updating
Selling my 18" Enkei's Evo 6 that I had on the Contour. Craiglist ad: http://tampa.craigslist.org/psc/pts/3099017245.html
CEGer's will get a discount, but I can only do local pickup. Send me a PM!
Oh and I'll be throwing in a bunch of left over parts I don't need that fit the Contour. Off the top of my head, I have set of window switches including master and a like new brake master cylinder, just missing a cap. There's other small bits, I think a coolant sensor too.
Err, well I haven't posted or owned a tour in a while, but the wife and I are in the market for a new car and damn do I want a SVT. Looking for under 4k and turn key as it will tote the kids as well. PM me if you know of any... my wife wants a MKIV jetta :/
Edit2: Still looking as of 2/21
Clean title in hand, owned by serious SVT enthusiasts its entire history. I have a 3 inch thick binder stuffed full of receipts and history about the car. The motor was built by Ryan, the administrator over at SVTPerformance.com. I have every bit of documentation dating back to 2002- receipts, build pictures, all the SVT factory stuff, dyno graph, head flow chart- you name it....Easily over $20,000 worth of receipts, including over $8,000 by me. Chassis is clean and rust free- It has always been garage kept and only driven on nice days. Has twice been featured in the annual CEG calender. Has quite a few one off and unique special order parts- it's truly one of a kind.
Engine:
-K&N Filter
-KKM MAF adapter
-BAT Intake Pipe
-Mustang GT Optimized Throttle Body
-SHO Shop Ported Upper Intake Manifold
-Bradness Upper Intake Manifold Spacer
-SHO Shop Lower Intake Manifold (Secondaries Gutted)
-Ported and Polished SVT Heads with 3L valves
-’01 3L Shortblock
-’05 Escape Oil Pan (revised baffles)
-190lph Walbro Fuel Pump
-SCT XCAL2 Tuned by LivinSVT
-MSDS Headers
-SHO Shop Y Pipe
-Magnaflow Resonator
-Bassani Catback
-Bradness Stab-o-Shock
-Solid Front Motor Mount
Transmission:
-Rebuilt and Cryo-treated by Liberty Gears
-Terry Haines Shift Tower
-Cougar Shift Forks
-Quaife Limited Slip Differential
-SPEC Stage 3 Clutch
-SPEC Lightweight Flywheel
-GCK Axles
Suspension:
-KSport RR Coilovers
-BAT 21mm Rear Sway Bar
-Bradness Rear Strut Brace
-Polyurethane Bushings
Brakes:
-12.2” Wilwood Front Big Brake Kit
-11.75” TCE Rear Big Brake Kit
-Wilwood B10 pads in front, Hawk HPS pads in rear
-SS Brake Lines
-ATE Super Blue Brake Fluid
Wheels:
-17x7 +38 Team Dynamics Pro Race 3s
-225/45/17 Falken Azenis RT615k
-ARP extended wheel studs
-McCann open-ended lugs
Interior:
-Sparco Torino Seats w/custom sliding bracket
-Focus Door Sil Plates
-Autometer Pro Comp Light Water Temperature and Oil Pressure Gauges
-AEM Air/Fuel Ratio Gauge
-SVT Build # Badge and Engine Plaque in Center Console
-VooDoo Shift Knob
-Aluminum SVT pedals; Saleen dead pedal
Miscellaneous/Weight Reduction
-SHO Shop Subframe Connectors
-Center Seatbelt Assembly Deleted
-Windshield Washer Reservoir Deleted
Exterior:
-OEM Style Carbon Fiber Hood
-Quad Projector Headlights by Pudmunkie (TSX lows, Hella 90mm highs, Audi LEDs in the bottom, Pro Burner Turns)
-Pro Burner Fog Lights
-3L fender badges
Maintenance:
-All fluids changed within the past 6 months: transmission, coolant, power steering, brakes, and clutch. Oil always changed every 3000 miles or 3 months with Royal Purple Synthetic and OEM filter. Royal Purple Synchromax in transmission, ATE Super Blue in brakes and clutch.
-new OEM lower control arms and hardware
-new strut mounts and bearings
-new GCK axles
-new driver’s side OEM front wheel bearing and hub
-new wheel studs
-new wheels
-new tires
-new brake pads (all 4)
-new rotors (all 4)
-new OEM starter
-new Optima Redtop battery
-remanufactured Motorcraft alternator
-new air filter
-new tie rod ends
-new shifter cables
-new wipers
I also have very rare blue Samco radiator hose kit special ordered from the UK, hasn't been installed yet but will go with the car.
Just purchased the car. It runs great, but it's not for me. I need a more "plush" DD. I will not part the car in any way , shape or form.
Engine:
-K&N Filter
-KKM MAF adapter
-BAT Intake Pipe
-’01 3L Shortblock
-MSDS Headers
-SHO Shop Y Pipe
-Bassani Catback
Transmission:
-Cougar Shift Forks
-GCK Axles
Suspension:
Brakes:
-SS Brake Lines
Wheels:
Interior:
-VooDoo Shift Knob
Exterior:
-3L fender badges
Maintenance:
-new GCK axles
-new wheel studs
-new wheels
-new tires
-new rotors (all 4)
-new OEM starter
-new air filter
-new tie rod ends
-new shifter cables
-new wipers
SHO,
Returned Your PM.... Oddly, slightly interested in making an exception for a sunroof car...
WTB an oil cap & Cougar parts
I need an oil cap. Since it's for a Duratec, I don't think it matters whether it's Contour or Cougar. (Sam & other junkyard searchers, I'd really like it if you could find me one by the March 9 meet.)
I'm also looking for some 1999 or 2000 Cougar parts: front bumper ('99/'00 does not have horizontal slots), fog light fittings & fog lights to match. Black would be perfect, but I'll take any color that isn't already carrying extra layers of paint.
Also interested in Cougar:
- door switches for window/lock controls
- passenger door wiring harness
- alarm horn (passenger side, rear)
- cloth covered (grey preferred) powered front seats
Off the top of my head, I'll say price on junkyard receipt plus 25% "finder's fee", but that's negotiable. If I get incredibly lucky & someone coming to the March 9 meet can find any of these, I'll pick them up there. Otherwise, I'll work out how to come get them.
-Marge
I'd be interested in the rear bumper depending on condition. Mine is some ugly faded mess.
