BurritaSVT
Well as most know I have one project on the way for the duratecs already the SC which I bought a rolling chassis for so the project will finish because like most projects I am waiting on the parts or a thrid party machine shop.
A local guy who knew of me very well had 4k in cash and came to me with a 240sx with a silvia body kit on it plus 300zx brakes LS1 Rear-end and a manual tranny converted. He wanted me to turbo charge his 2.4 liter stock motor but I told him I am not interest in doing stuff already doen before. I like to do new projects where I can make copies of and resell to other customers. I don't need the money but I like to have the publicity of doing a swap never done before.
Well As most know the 95 nissan has alot of room under the car and is RWD.........
so I told him I would do a turbo duratec with LS Tranny. Now I will buy two motor taurus 2004 and a LS motor to see if I can use the taurus motor instead of the harder to find LS motor. We will build mounts and make a bellhousing adapter plate so that we can mate up the taurus motor to the LS tranny. We will keep it single turbo for now keeping the stock bottom end.
The benefits to usign the duratec is the weight is less or the same as the stell block by nissan. The Duratec we know can handle over 400hp stock parts so if we can get the tranny to hold under boost we will have a quick car. I will be posting pics of the whole build here. The guy is going to give me $3500 up front and just want to make sure we beat his brother build who had over 5k in the SR20DET motor while keeping the cost under him too. I will mock up everything and make duplicates because if this projects does well I can see this kit selling alot especailly for us Duratec fans.
Now I found a tranny for $320 and a LS motor for $550
Here are a list of parts I think I will need
Engines LS 2003 & 2004 Taurus
Tranny LS $320
Drive axle
Motormounts LS
SVT cams
LS flywheel
LS clutch
LS P/S or Taurus
A/C bracket Fabbed the Nissan compressor same spot on car great
Maybe the LS intake or the Mazda6 reversed or SVT reversed with spacer
Contour Alternator
MSDS headers modified
300 ZX radiator w/ fans
Contour PCM with wiring harness donated by Bagged
Fuse box harness donated by Bagged
NPG custom turbo kit
Our goal is to stay under 5K in parts
and make 375 whp at 12 psi
I will be getting the car two weeks once his truck return from the body shop less then two weeks.
This will be fun especailly when I can do it at someone else expense.......
Tranny LS $320
Drive axle
Motormounts LS
SVT cams
LS flywheel
LS clutch
LS P/S or Taurus
Contour Alternator
