green SVT
Guest
When will pricing be available for this?
After I thought about it for a little bit.... this is really only a simple addon for a stock 2.5L, since a modified one will require larger injectors, right? What I'm figuring is that for a stock 2.5L (165hp) to get to 220hp with this kit... that's 55hp more. If I'm at 183hp now, that would put me roughly at 238hp. And the 19lb injectors are only good for ~230hp?
I'm debating whether this kit is more economical for power than a 3L. Only thing is won't a 3L hold more boost(why is this?). How much more power does the turbo that is efficient at low boost make than the turbo meant for higher boost when at the same low boost level?
I'm not sure but I think most 3L's (besides the "true" Hybrids) have a lower compression ratio than the SVT motor thereby being more boost friendly. However I could be totally wrong![]()
Interesting! I've been flip flopping between wanting a 3L or your base turbo kit... now I'm not sure (again).No if you have a returnless then you are limited to 238hp but if you are return style you can go up to 250+ I hit 235whp intercooled with stock injectors because the mechanical regulator is held close while on boost. Joey
There aren't any dynos of a modified 2.5L (headers, & other bolt-ons) with the intercooler-less kit, are there?
