RawBurt
Sweet, finally some pics!!!! only thing i'd suggest is rerouting the hoses that run over the intake at the TB. Run them under the intake pipe and it will look much cleaner.
It is supposed to be 68 degrees Thursday, a far cry from the 40 and windy today. I'm getting the o2 bung put in tomorrow for the wideband. I've gotta find a better camera for calender submission pics!
Rod
So, we have a leak somewhere that is pulling in unmetered air after the MAF, thus scewing the numbers and making it run lean. Well we find the leak. We had a pipe that did not fit quite right. The 90 elbow coming off the cold side of the turbo needed to step down to properly seal the piping going to the MAF. We bought a section of 3" pipe and a 3" to 2 1/2" adapter, cut a short section of the 3" pipe and attached it all together.
I don't believe I have this issue. the pipe out of the maf is 3" and so was the inlet into the turbo. however the clamp doesn't sit to well because of the curve of the pipe. but then again yesterday in the cold I was running plenty rich to be safe.
Yeah, once you go from the 2.5" intake pipe to the 3.0" intake pipe, the problem is no longer the diameter of the silicone coupler but rather the curvature of the pipe. One day after the kinks are ironed out, I will replace most of the silicone sections with pipe.
I'm pretty sure all of my intake pipes are 3". I seem to recall getting a 3 to 3.5" and 3 to 4" coupler so that I could use the 80mm maf and maf adaptor. that would mean I have a 3" to 3" 90 degree elbow for the turbo inlet.
That sounds right. In my case, though, I started off with a 2.5" intake to use with the stock MAF.
