2kSVT
OK, so I got the new injectors and harness from Joey this afternoon. We install the harness and injectors and test that they have power before putting it back together. We apply turbo tune to car, and the moment of truth. It starts and runs for about 5 seconds and dies. It then just turns real fast and no start, kinda like no compression. So we take it back to stock tune, to see if it makes a difference. Same result.
I talk to Joey, check for fuel..yes. We check that we have spark from the boot..yes. When you turn it over it just sounds like no spark/compression.
One of my buddies was checking injector wire harness with pointy voltage tester. At this time I was re-installing turbo tune. During the install, the Xcal says download malfunction and stops dead in it's tracks. Now, when you turn the key there is nothing, no idiot lights or sound. I call Joey who has me call SCT direct. The guy says it sounds like a fuse or something as the Xcal cannot recognize the key is on. After some time with them, we check every fuse in both boxes. The SCT guy says he has seen 3 computers fry during download using Xcal in his 3 years there. As we are scouring the car for the problem, I see a hole poked in one of the red injector harness wires under the UIM. Could it fry the computer if he went clear through the wire and touched the metal fuel rail. I was in the car when the download failure happened. He was checking the wires at the same time. Are our pcm's truely unique?? Advance auto says they are the same, and $270+ $75 core, and they have to special order it.
This does not explain, the stall and not re-starting, but now it won't take a tune or recognize the key. This is my DD and it has been down for a week. I'm throwing $$ at it and I need it running. I can't rely on borrowing the neighbors car much longer. I need help guys! Thanks
Rod
Rod
