what is the gray peice that is bolted to the coil pack, and what does it do. i know it's not just a ground because it's connected into the live wire for the coil pack... any ideas?
I have a Zetec engine and I have a grey plastic connector that is however not bolted on coil pack. It(actually the plastic connector case) is attached to the metal coil pack holder and I am pretty sure it is sort of grounding. If it was hooked up to a hot wire, my car would be smoking right now knowing that the other end of the wire is grounded...
it's on the duratec... but that's what i was thinking about the hot wire being grounded but i wasn't sure that's why i was asking. the thing is the wire was connected from the factory so i know that it's pretty sure it's supposed to be like that and i've seen it connected to the coil pack bolt on every diagram...
