Hey guys,
So it's finally happening! It's been my dream to turbo a Contour SVT for literally years. I'm finally at the point in life
. It took a great deal of sacrifice, but the best things require hard work and planning
I purchased a kit from Justin, who unfortunately had to let the kit go. He is starting a family so I wish him well, and assured him that the kit will get installed and treated well. I've spent the better part of the last few months researching almost every aspect and component in a turbo system. Being not only my first turbo kit, this will be my first time driving a turbo car :help:. I've been able to answer all my questions but six, which hopefully someone with much more experience than I have can chime in:
If you can spare the time, I actually went ahead and made a 15 minute video (in two parts) of everything I have so far (minus the parts already on my car: such as a racing clutch, lightweight flywheel, Remus cat-back, and a K&N with Pudmonkey heat shield). It's actually a fun watch that can double as a checklist for CEGers in the future :laugh:. Please feel free to comment on YouTube and CEG if you'd like.
Part 1 - http://www.youtube.com/watch?v=MpmvbhppTmQ
Part 2 - http://www.youtube.com/watch?v=31rKVLh9dR4
Questions:
1.) The kit came with a Tial BOV. While I read that this is a great BOV, I've had my eyes set on a HKS SSQV (version 2 or 3). SSQV+ CSVT = :drool:. However, I read that a VTA BOV could foul my plugs and/or bog my car down with potential backfiring due a rich spike on shifts/while letting off the throttle. In that case, Alex says that their is an adapter for the SSQV so that it will recirculate. While it may hinder sound, it's probably the safest route. I took a look on eBay and Amazon (btw eBay is loaded with fake BOVs :blackeye
, but they all seem to be vehicle specific. Is there a specific size/model number of the BOV and recirc adapter kit I should look for? I doublt I'll see a "HKS SSQV2 BOV for Contour SVT" or "HKS SSQV recirculation kit for Contour SVT" anytime soon :laugh:. If anyone has a used 2nd gen or 3rd gen lying around, please let me know!
2.) I don't know much about the turbo itself besides the information stamped on it. A Google search yielded some confusing information. If you can, check out the Part 2 video about a minute and 15 seconds into it. I posted a chart I found online. However it displays two trim numbers and two A/R numbers (compressor and turbine). Which one is used when people talk about their specs? I was also told that this is a pretty big turbo with a "massive wheel." What do all these specs mean as far as the power band? With a .50 A/R stamped on the turbo, I'm guessing that boost will come in on a fairly low RPM. Or does the bigger than average wheel take more time to build up, raising the boost band? Just curious as to what I should expect. With the Torsen, I should be able to put the power down to the ground, but if it kicks on hard & fast, that may be difficult for street driving. I don't plan on going higher than 8lbs of boost since the 'tour will become my new DD once I sell my Civic to recuperate some of the Contour cost.
3.) With a 8lb wastegate, I should be fairly safe with a stock engine (using 42# green top injectors), but how much pressure will this turbo make? Is a 38mm wastegate (shown at 7:35 in Part 1 video) efficient enough for this turbo? Everyone says to go 50mm to be on the safe side (to prevent the waste gate from getting backed up and an undesired increase in boost), but I'm wondering if I'd be ok using this one. I'd hate to order another wastegate, but I tend to worry (more than I need to sometimes lol). FWIW, Justin tells me that this is the wastegate that Joey includes with his kits.
4.) The Torsen is used, but should work perfectly fine. It did not come with a speedo gear or bearings though. I was told the speedo gear can be resued, but I don't know the part number for the Ford bearings? RockAuto only sells Timken (which are surprisingly only $5 but I've never heard of that brand). FWIW, I have a cougar trans (possibility out of a '99) but I don't think that the diffs were different. The part numbers are most likely the same.
5.) Greg says that, most likely, the engine and trans will need to be pulled to install the Torsen, and to tap the oil line into the engine block. This got me thinking. While it was not my original thought to consider a 3L swap, would now be the smartest time to do so? Since an engine has to go out, an engine has to go back in. My 2.5L has just over 100k miles and I would hate to retire it so early, but a 3L can handle the turbo better, offers more torque outside of boost, and may have lower miles. Also, I've noticed that the prime engine is a 2004 Escape. I read that 2005 was the first year for cast cranks, not forged (which I was told were designed with lower RPM use in mind - like 6 speed trans - which definitely won't do). I also think 2004 was the first year for the better flowing intake. Plus I forget the starting year, but I believe 2004 had the updated cams which were similar to the SVT's specs.
6.) My car came with a 2 gauge pod from the previous owner. Currently it has a vacuum gauge, and a disconnected narrow-band A/F gauge which he put there for show :\. I haven't purchased any gauges yet, but an AEM wide-band A/F ratio gauge and boost gauge are two I'd like to get. While I only have room for two gauges, do I need a temperature gauge of some sort for the turbo? Since it has an electric cooling system with a switched pump, I'm guessing I would need to turn it on when the turbo runs hot, but I would need a gauge to determine that (or do I use the engine temp for determining that)? Sorry again for sounding naive, I've never actually driven a turbo car before and I want to take care of it properly. If I need a temp gauge, am I looking for an oil temp gauge or some type of coolant gauge? Or oil pressure gauge? I have seen pods for 3 gauges out there if I do need 3.
Sorry for the novel of a post, but be thankful for Google! Otherwise my boatload of questions would have came pouring into CEG :crazy::laugh:. Thanks so much guys. It means more than a lot.
Shoutout and thanks to Justin, Greg, Adam, Alex, and of course, CEG
Questions:
