Haha well aside from the whole research thing that you're supposed to do I'll tell you everything I can remember off the top of my head. We will start from the top down for what you're doing. 2.5 TB, UIM, LIM, fuel rail, injectors, port match plates. If you are using SVT cams use 2.5 timing components, 3L cams 3L timing components. Flip pulse wheel to the other key way, 2.5 timing cover, valve covers, and accesories. I think the water pump can be either. (not to that part yet so not sure) you can use the 3L oil pan, tray, pickup, dipstick and pump. Can use the 2.5 oil pan, and pickup but have to mess with the main studs to get a bolt on for the pickup. Others just switch to the escape pan and pickup. oil pump is the same for all of them. 2.5 wiring harness. um thats all I can think of if I missed something hopefully one of the experts will catch it because I'm doing my first one too I've just done alot of research.
