Devilsword
here it is really stock 2000 csvt manual black and tan with wheels off a 98. 160000 miles new tires, clutch, brakes, pads, rotors, and a ton of spares (extra skirts, bumpers, lights, engine parts ect.). he also tossed in a set of motegi track lites for a little extra. in the end i paid 1700 for everything and i still need to pick up another truck load. did some cleaning, repaired the engine mount, and replaced the sunroof motor so here are the pictures.
here is a picture of the broken engine mount. the bolt sheared completely off so i replaced it with a grade ten with a crush washer. if anyone want to know the bolt is a M12-1.75 x 40mm. the other problem i ran into is erratic hesitation with no CEL. sometimes at 5000rpms sometimes at 6500rpms sometimes at 4200rpms. i read about problems with the the fuel pump with a 1/4 tank or less. going to fill up tom and see if it fixes it but already looking to pick up a new filter. don't know when i will tackle replacing the whole pump setup. ALso i seem to have a problem getting into reverse(i though fixing the tranny mount would help this) i checked all the linkage is there anything else i should look into for that or just in general to inspect this new car?
