Almost got things under control...
Well, everything seems to be running good.  Tires fixed, moose seems to have wandered to greener pastures and my fuel pump seems to be running okay (lingering concern).  However, I still have one problem I can't seem to figure out.
My check engine light comes on for a minute or so when I'm passing or going up a hill.  Originally, it only happened when I revved high on the freeway.  Yesterday, driving home, it happened while I was driving a particularly hilly segment of road near our home.
I've checked all the rubber boots and hoses which deal with airflow.  Nothing.  I've checked the engine codes and never find one.
Few questions -- I still haven't changed out the plugs and wires.  Probably needs it regardless of it fixing the problem.  I've run the KOEO test with the scan tool and it shows no codes.  I can't seem to figure out how to run any other tests.  Also, since the light only comes on for a minute or so, does it not save the code?
Thanks for any more advice.  Things are finally starting to come together.
