striker2
Official CEG Vendor
what gaskets are you guys using? like SHOgoFast, i never had a problem with blowing out the gaskets at both 10 and 13PSI. i was using the metal gaskets for both sides of my tial 35/38mm
Tial did away with the squishy metal gaskets, because everyone was blowing them. Their new ones look like our header gaskets -- sheet metal. It's not possible to blow half of those out.first set was what ever came with the wastegate I got from NPG. Like I said I didn't tighten it down so thats one on me. Next I got a sheet in intake/exhaust gasket material from Napa. It is metal core with paper outside. I assembled it with red silicon sealer. the paper gave out and it started leaking. last time I did the same thing, cut the material larger then the flange and assembled dry with red loc-tite on the bolts. been good ever since.
I don't understand the wg gasket problems either. Never once did I have an issue on my car, and I ran 11 to 12 psi daily, also spiked 15+ psi when dialing in the mbc. sounds like you are having nothing but problems with the kit. I cant imagine the hell you are going through with R&R with that wg :help:
I tightened the wastegate before installing it into the car. made the turbo alittle hard to bolt in but the wastegate hasn't been an issue.
Brapple is right the recirculating is an alignment PITA. Rawburt knows this first hand, he installed mine for the first time. This is when it was all new. After, I retighten the header nuts, I hope it will be ok. I will reinstall the boost controller, and run 10 psi. I just don't want to have to do a 3L right now. Reebs be on standby when I do!
Rod
Maybe it only blows out with high levels of boost. :shrug:I don't understand the wg gasket problems either. Never once did I have an issue on my car, and I ran 11 to 12 psi daily, also spiked 15+ psi when dialing in the mbc. sounds like you are having nothing but problems with the kit. I cant imagine the hell you are going through with R&R with that wg :help:
If that were the case, mine should have blown out when I spiked 15+
mine was recirculated and i was running 13PSI without blowing out the gaskets. but i was using the steel plate gaskets.
I was referring to people that consistently run 15+ on it, and have it recirculated. All I'm saying is that Tial acknowledged that blowing gaskets on their 35/38mm wastegate was a common issue, and they redesigned the gaskets to fix that problem.If that were the case, mine should have blown out when I spiked 15+
i believe i got all my steel plate style gaskets from ATPturbo.comspeaking of heavy cuty gaskets where is a good place to get some? would they be of any benifit at the turbo either?
