giddyup306
Oil is used because it is a liquid and can be pressurized into bearing areas. It's a fluid layer under pressure that keeps the metal bearings apart. fluid is not compressible like solids.
Foaming means that like soap bubbles there is gas trapped in the oil, Air. This IS compressible and means that the layer of fluid can no longer protect the bearings becaus the air in the oil will compress under pressure and then the metal will make contact.
If Demon is right that it foams, I would get rid of it.
Maybe you should just change to a thicker multigrade oil.
My Volvo owners manual is one of the first manuals I've read that actually explains to run thicker weight oils in higher summer temps and thinner weight oils in cooler temps to prolong the life of the engine. It actually states that at the expense of some gas mileage the thicker oil protects better.
<polishes fingernails on shirt> As I've been touting for a while.... lol
I recommend 10w40 for summer or temps. I used 20w50 in Az with 100-115*F temps.
Do the math for a vehicle like the Ford Explorer (400,000+ per year produced since introduction in 1990). $5.50 x 2 (.2 MPG shy of the average set) x 450,000 = $4,950,000!!!If the average fuel economy of a manufacturer's annual car or truck production falls below the defined standard, the manufacturer must pay a penalty, currently $5.50 per 0.1 mpg under the standard, multiplied by the manufacturer's total production for the U.S. domestic market.
Actually, it's probably like 0.2 - 0.3 MPG difference ... 1 - 2 MPG is astronomical for a simple lubrication change. However, every tenth of a MPG counts ... according to CAFE regualtions:
I run 10w30 in the summer in MI (it doesn't get too hot here), and 5w30 in the fall/winter.
you do realize the only benefit you are getting is thinner oil at start-up right? because at operating temps both those oils have the same viscosity.
the better summer/winter change is 10w40/5w30 respectively (for places like michigan).
Holy CRAP! :shocked:
That is a lot of cash. I can see why. Well like I said, at least Volvo is straight forward about it. I can even scan the page out of the owners manual and post for the really curious...or maybe someone can find it online.
This is one of the reasons that I really like my volvo. The other reason is the 4yr - 50K mile comprehensive warranty that covers all oil changes while you are at it. I still change the oil in between the dealer changes but it's nice.
Also, most car companys offer split warranties, where they give a really long powertrain warranty but only a two year comprehensive, and stuff like that.
