Lotek Gauge Pods :: Interest
Status
Not open for further replies.
It seems there may be some trouble for people trying to figure out how to purchase the pod(s).
From www.gaugepods.com
On the left, click "Auto"
On the left, Click "Ford"
The very top shows the Contour Pod.
Click "Select Color" and duhh, select the color.
Click "add to cart" right under the "select color".
This will bring you to your cart, and the beginning of the checkout.
On this page, is where you enter the coupon code. Enter
the code you received in your PM, and click "redeem code" to activate it.
After you have clicked redeem, click "Process order" right under "redeem".
If you cant figure the rest out, you should be kicked in the nuts and thrown off the internet.. :laugh::cool:
FYI: I am going to make the discount code public tomorrow (Friday)
at 12 midnight. So everyone on the list,make sure you hurry up an order so you do not have to wait for backordered pods. :cool:
I've decided on Autometer phantom gauges. (white faced to match the cluster)
Boost 30/20 psi
Oil pressure (Electronic) 0-100psi
Pyrometer (EGT) 0-2000*f (I really should have 2 of these though)
They are all for the addition of turboooooooo.. :cool:
My Scangauge has the below digital gauge functions, so I am pretty much set after the above 3.
  • Fuel Economy
  • Fuel Rate
  • Battery Voltage
  • Coolant Temperature
  • Intake Air Temperature
  • Engine Speed (RPM)
  • Vehicle speed (MPH)
  • Manifold Pressure (not available on some vehicles)
  • Engine Load
  • Throttle Position
  • Ignition Timing
  • Open/Closed Loop
Boost 30/20 psi
  • Fuel Economy
  • Fuel Rate
  • Battery Voltage
  • Engine Load
  • Throttle Position
  • Ignition Timing
  • Open/Closed Loop
Well then please set up another GB for the gauges. 25 x 3 = 75. That will be a good bargaining chip to set up the GB.
Thanks!
Thanks!
Set it up with who? I am ordering mine from Summit. I doubt they will do bulk discount, but I can ask .
FYI, for people who dont know what gauges to get, if you only know of 2 that you want now, and nothing for the third hole, Lotek sells a pod hole cover for $3.99 http://gaugepods.com/gaugegear.html scroll down to the bottom.
ordered and paid up!
Yep gotta look for some nice glow gauges to finish off the look :drool:
What gauges do you recommend? I'm going to get a Air/Fuel band,Voltometer
...not sure what else :confused:
don't bother getting one of those cheap air/fuel gauges all they are is an expensive light show. I'm going to get oil pressure for sure, not decided on the other 2, maybe volts...kind of depends on what other mods I will be doing down the road.
There is actually a *fix* for the brinky rite LED gauges. It still sucks as a tuning tool, but it makes it less sporadic. I still believe in digital AF gauges.
Ordered.
Thanks for taking the time to set this up!
Nice coupon code. ;)
just a question. im looking for the auto meter gauge now.. whick one light exactly like the svt gauge (green and red) ? is it the ultra lite ?
The ultra lite is a silver face background.
Nothing is exactly like the svt gauges.
But, I am getting the Phantom white faced gauges.
They have a black bezel ring.
For the light, you can change it to whatever you want. Either by buying a green bulb, or a clear bulb with green cover, or my choice; changing them over to green LED.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=3691
The Ford Racing gauges are white faced also..
I really like those gauges also, but.. The nice thing about buying gauges, is if you ever sell the car you can always swap them over. And what happens if I buy a Camaro or Corvette or something & have ford racing gauges in it.. :D
Well, its not 12 midnight- but I'm not going to be around until late late tonight. So everyone that was on the list, I think you've had your chance :D
Lotek Pod Code: divinitiowns
20% off- ONLY Contour/Cougar/DSM pods!
Status
