bensenvill
I'm guessing it's a quote from another episode
http://www.southparkx.net/episodes/1114-the-list
that episode is the only thing I can think of anytime I see any of the south park girls.
Any chance you have a spare 3rd brake light cover laying around? I know you are stacked with parts :laugh:
So what happened to the ABS light?
Check the abs sensors at the wheels. They like to get broken anytime you touch them. Make sure no one installed non abs cougar hubs on your rear spindles......![]()
The wheels will come off next week and I'll look into it then. Todays project is getting the dash out, not a big deal...Then I'm off to buy paint. I'd like to get the door panels painted today so that after the components are re-installed i can fit them up and get them off the shop floor.
For those that were wondering compression was 225 across the front bank and 200-215 across the rear bank.
Can't wait to see this car when your done, It will have come along way, your doing great work to the car..hmm I may need some work done to my svt over winter, you have anytime for some same projects?
Compression in the front bank don't seem to bad the back is a little low but the motor has what 155k on it? So doesn't seem to bad, nothing I would worrie about! Was this done when the car was up to temp?
There will be three SVTs in the shop all winter, so space will be non-existent..what exactly do you need done?
Test was done cold as at the time i had a ton of shiz tore apart to swap parts. I wanted all the CELs and crap gone before i pulled the motor.
I'll pm you so I don't steal your thread, won't the compression readings be a little higher at temp? Now this may be a dumb question but are the compression numbers the same from the 2.5 to the 3l motors? What should good readings be, I'll be checking mine this week and was wondering? Thanks
The seating situation should be almost totally handled. Thanks Mr. Barnes!
	Where did you get those?! :laugh:
What a waste of paint :nonono:Powder coat Josh maybe?:shrug:
