Hey again guys,
I'm sure everyone read about my dilemma with the trans. Toying with the idea that the trans will have to be dropped again, what are some things you would suggest putting in the car while the trans is out? This is just for planning as I don't have the funds at the moment. Though I just applied for a second job
. The car we'll be talking about is a 98 CSVT with almost 100k. The only current mods would include an intake, Remus exhaust (compliments of previous owner), and MSDS headers.
First I would probably opt for the Fidanza light weight flywheel. At roughly 7 to 9 pounds, that should make a big difference. Then I'd probably opt for the Quaife or Torsen differential. Not sure which one is better :shrug:. Then lastly I'd consider a clutch, but mine still holds like a charm (tested it when I had to drive 7 miles starting in fifth :nonono:
). So maybe a clutch isn't necessary. Plus it's a pricey penny that isn't really necessary at the moment.
Any other suggestions?
I'd probably also have the alternator, PS pump, or something else on the accessory belt looked at too. There's a slight whine (not as bad as my 96 was) coming from the same area. I'd guess the alternator since that was the issue on the 96. Though everything on that belt seems to be working fine. Just a little bit noisy.
I'm honestly thinking about borrowing someone's dolly, strapping the SVT to it, and driving up to Air Cougar to have the job done right! Though then I look at my bank account and wake up
:laugh:.
