I've never driven another Contour before, so I have nothing to compare this one to. But, it does seem to have strange shift behavior. It seems to downshift way too easily for my taste. If I give a 3/4 throttle or so after reaching 60ish mph and it has already gone to OD, it will downshift (rather sluggishly) and it won't upshift to 3rd until near redline unless I take my foot out of it. I'd rather it not downshift unless there is a significant load (going up hill) or the pedal is mashed to the floor. It seems to downshift right past the "sweet spot" in the power or torque curve. The shifts also seem to be rather sluggish when downshifting. I'm used to a more "positive" shift. It almost feels like some strange clutch slip as the RPMs rise and then the engine and tranny finally couple.
This car was badly neglected before I got it. I'm actually amazed that it runs at all, but I've worked through most of the issues over the course of a couple years. I got the car free from my ex-bro-in-law. It had sat for 1.5 years on flat tires and a dead battery. He let me have the car, so I got a battery and went to start the beast. Popped the hood and discovered that squirrels had made a home under the hood over the winter. They made a nice nest in there and had chewed off the plug wires, the MAF harness and a couple other wires. Luckily they left the main harness alone. So, got a set of wires and plugs. Battery. Repaired the MAF harness, etc. Got it started, but it smoked like a coal fired freight train. CEL was on, which he told me was always on.
So, here's what I've fixed since I got it:
Had 14 steel wheels, so replaced with a set of SVT wheels and decent tires.
Had to repair the driver's seat. PO was 380+ pounds and had actually broken the seat framework just above the lumbar region. Also snapped the spot welds under the seat where the X bracing was. Pulled the cover off and did some spot welding and grafted in some steel to get it close to normal.
Changed tranny fluid.
CEL was on and ended up having to replace front and rear upper O2 sensors. (fun).
CEL still on. Replaced top end gaskets.
CEL came back. Replaced gas cap.
Blew a rear strut. Ebay hooked me up. 2 for 1 on new (OE type) struts.
Engine was severely sludged up from infrequent oil changes. Ran some seafoam through it. When I replaced the intake gaskets and valve covers, I cleaned those up first. The TB was carboned up badly, and I don't think there was any flow for the EGR or air bypass valve.
Late last fall, the alternator died, so the car has been sitting until about a month ago when I began the next round of repairs:
Leaks oil. Thinking it is coming from the front cover, the crank seal or the pan gasket. I had already purchased these gaskets/seals, so I spent a couple weeks tearing off the bottom and front of the engine. The exhaust bolts had to be cut off (spent 6hrs in the ER after I got a metal fragment stuck in my eyeball). I went ahead and pulled the intake and cam covers off while I was working on the bottom. Figured I check the state of the sludge... Good thing was that having the top end tore down made removing the alternator much easier. Easier to get to one of the top bracket bolts. After getting it all back together (and getting the plug wires in the right place on the coil pack (had 1 and 3 reversed)) it runs very smoothly.
Still have an oil leak. It appears to be coming from the block near the AC compressor. I'm suspecting that the seal between the upper and lower block sections is leaking in there. Unless there is a sensor screwed into the block that I can't see. It is not leaking from the cam or crank sensors.
Ok, so most of that was way off topic, but you can see what I've had to go through to get this "free" car reliable. I still have to do suspension bushings front and rear and probably bearings all around. Fix cluster. Fix clock (has separate clock, not on radio) bulb. Change trans filter. and fluid again.
I'll take a look at the VSS wiring today. I'll pull the cluster and give it another look. Is there any way to "probe" the harness with the car running to check for VSS signal to the cluster?
Thanks,
Tony
