Can the cam and crank sensor (I assume both a hall effect sensor) be tested?
a) off the engine?
b) with engine cranking (but not running)?
I assume the signals of both sensors are coming/going to the PCM
on my 95 Duratec ECU PCM, what are the pin numbers?
a) off the engine?
