Ironically, I am experiencing this symptom as well.
stuttering/sputtering under 60-70% throttle or more.. any speeds, really, any gear (well. except first, really.. 2nd on up, though)
I started with new plugs..
then new wires
finally measured the coil and it was "technically" out of range so I swapped it out for another one.
no change
At this point, I'm thinking maybe my TPS is going out.
Then, I lowered the boost level to 3psi (just to eliminate all factors I could) and the problem went away completely. As long as my wastegate opens up before about 6 psi or so, I don't get the problem.
Now, I am thinking I am blowing out my spark at 6psi or higher and I am going to pull the plugs, and re-gap to 35 or 37 thousandths.
