ok, I know this is simple but I ran into a problem I never ran into before.
first I replace the fuel filter on my mystique yesterday morning. I pull the fuel filter fuse under the hood and changed the filter. I got alittle gas out of the line, no big deal.
now I try to change the fuel filter on my SeVT-T. I do the same thing, I pull the fuse and crank and let the engine run til it dies. I then crank it a few times to make sure. Just like I did in the morning with the other car. Well i go to pull the line off and I get fuel spraying out with some force. I quickly put the line back on as to not dump to much fuel out. I tried cranking it a few more times and the same deal. I even unplugged the pump to releave the pressure when I cranked it over.
I know some fuel will come out of the lines but I have never seen it under pressure.
oh the difference between the 2 cars was the mystique was just about out of gas and the contour had about 3/4s of a tank.
I do have the walbro fuel pump and 42# injectors if that matters.
So what is going on?
