elraido
I kant speel
I want to say its around 113-114 mph.
i want to say that as well.
I thought I could help in this conversation. I am very lucky in having 2 complete transaxles. The first one is a complete Quaife straight cut dog box with a Quaife diff. The second is a Houseman synchro gear cluster in a Liberty prepared box with a Quaife diff. The clutch is a Quartermaster 3 plate on an 8 lb flywheel.
My car only has about 290 hp N.A., but the complete Quaife setup works very well. The car uses 235x40x17 Toyo RA1's and seems to have more than enough traction once the tires are hot. I have never run the 1/4 with it, but from a standing start it slips the tires a bit then hooks and goes. The one thing the Quaife dog box gives you is the ability to almost flat shift the car like a bike. A lift of the throttle and BANG into the next gear. The ability to shift faster really allows stronger acceleration and less rpm drop between gears. This gives you a faster 1/4 time.
The down side is that the dogs need to be refaced fairly often to keep it from jumping out of gear. If you need to replace the gears, they run between $300 and $900 a gear. I haven't priced the dog rings yet.
I have little to no torque steer with the car as well. I am in the process of putting the Houseman box back in the car while I have the Quaife rebuilt. I can let you guys know how it works in about a month. I also top out at about 152 mph with the final drive in the car, but thats fast enough for me.
Eric Nummelin
Yeah but what kind of car is all this in?
I am at a lowly 110mph, on 9psi, 5.5"x 14" rim with a horrible 2.3ish I think 60'
here is a crappy vid of a 12.9 @ 109mph run vs. a WS6
http://www.youtube.com/watch?v=b_UX1RbCqrg
At least people have you beat on the 60' time. :blackeye: Those are all naturally aspirated guys though.
and well, I think I finally found some cars that have worse traction than my car lol
If you want to see a bit more, need to update the site a bit, go here....
www.nummelinmotorsportgroup.com
I would like to take credit for the car, but it is the ex-Mumm Bros. WC Cougar. They built it all and all I am trying to do is bring it back and get some hot laps in the car. The technology in this car is top notch and little expense was spared. I don't think it would work well as a 1/4 mile car as it is too heavy (about 2450 lbs) and while it plants the tires well, it does try to spit axles and diffs out at its first chance.
Eric Nummelin
Back on the subject of hitting 12's. I'd like to think the supercharger setup I have would perform better at the track for a traction limited car with weak axles. All the power is in the upper rpm. Also the poster talking about eliminating turbo lag which his huge turbo may want to think again. It may help him gain traction before boost kicks in resulting in better times.
The only way to improve my setup or even a turbo setup would be to run different boost levels in different gears as mentioned earlier. Setup a way to detect which gear the transmission is in and then dump pressure over a certain psi in each gear until 3 or 4th roll around and then run full boost. I'd imagine you could hit 12's fairly easy with that setup and save the axles in the process.
u're probably right. the only person i know that has a boost controller with that setup is ryan(ryanblacksvt). am not sure when he plans on installing it tho...
Its been installed but its a MBC, there is a flight switch and when its up its at 8psi and flip it down and its at 14psi. The next best thing is the ams1000 boost controller which will be had VERY soonBut what I have now is definitly good for the track, I couldnt imagine trying to launch on 14psi:crazy:
oh. thats the one i thought u had already. the ams1000 one. for a while now, u said u'd be getting it. so i assumed u'd have it by now.
That was the plan but I am running late.
cool. by the way, hope u're feeling better. get this thing installed so i'll know if i wanna spend another grand on SVeTlana. sick n tired of losing to 150hp cars from a dig:laugh:
