SkullV
Yeah...cryptic post..ill explain when I get home and can scan some dyno graphs tonight.
...this post doesn't make a whole lot of sense to me.
Ian aka jared doesn't ether to me :laugh:
Thank Kim for that one. I'm still waiting on the explanation of how the presence/absence of cats changes whether your car has the tendency to run rich/lean.
I dunno man. I was always under the impression the upper O2's were relevant to air/fuel metering, and the lowers were just cat monitors for emissions purposes.
Well from the start I have been specific with the Contour only. I haven't made any suggestions of any other vehicles as I am not familiar with the design of their cats. I have seen the Duratec cats and I have had discussions and read many discussions about the potential gains for gutting, and I stand by my deduction that gutting the cats will keep you at stock power at best. :shrug:It'd be nice to see a flow test or dyno runs done, though.
I would like to see fuel trim readings for a car with stock, working cats, compared to a car with gutted cats. I bet you $20 they are nearly the same.
I still disagree. I've never seen it proven. :shrug:
You know....you honestly are a genius....wtf is the point of installing mil eliminators?I would like to see fuel trim readings for a car with stock, working cats, compared to a car with gutted cats. I bet you $20 they are nearly the same.
Well I'd think the STFT would be the FT affected, because the flow difference, if it exists, would only be noticed under higher RPM, when the engine is really getting pushed.
and that is for every car that has a cat, not just the Contour.The entire purpose of instaling the "o2 sims" in the post cat o2s is to eliminate the check engine code and pass OBD2 emissions. Zorrex is right, the post cat o2s have nothing to do with vehicle performance and only shows cat efficiencey.
no, the PCM never looks at the downstream sensors to determine whether it should adjust the fuel trims. It only looks at them to determine if the the cat(s) is functioning properly. that is the only role of the downstream sensors, nothing else.THe rear o2 monitor flow after the said cat. If the mixture is uneven then the computer makes adjustments.
Each bank 02 adjust for each side. IF the upper sensor initial readins are accurate...and lower 2 are off. Then it makes adjustments accordingly.
If the lower o2s read a change...then the car will go either rich or lean. If that occurs then the fuel trims will change based off the o2's readings. Only to prevent the cat from being dmaged even more and keeping the cars emissions within it's area.
