hey guys/gals. I've just recently developed a problem with my csvt. here is my issue. I was down to less than a quarter tank so I added some gas from a 76 gas station. (I use Shell) the car ran good as its always been until 10 miles later It started losing power. well i pulled over and it didn't wanna start again. he're is the real trick. NO ENGINE CODES! well I had it towed home and its been sitting in the driveway. i will start and run for about 5 min then die again. still no engine codes! when it does run it'll run good spitting water out the twin pipes then it'll sputter spitting black carbon and you can smell fuel from the intake. the only engine code that has come on was a P1132 rich condition. which leaves me to believe fuel is not really an issue. i'm thinking my coil is going bad. or could it really be a tank full of bad gas? oh by the way I sprayed around the intake and hoses/vacuum lines no vacuum leak either.
