95_Mystique
anyone know the specs on the stock Zetec cams?
Stock
Duration @ n/a Tappet Lift : 290/286 degrees (Int/Exh)
Duration @ .050 Tappet Lift : 206/205 degrees (Int/Exh)
Lobe Center Spread : 111 degrees
Lobe Lift : .352/.343 (Int/Exh)
stock focus intake cam
.348" lift, 202 deg duration @ .050"
stock zx2 intake cam
.367" lift and 214 deg duration @ .050"
what kind of numbers can u get with a set of cams, with a mild grind, say the 2500-7000RPM range?
maybe +10-20 but youd need a tune and bigger injectors to support it
you might want to do headers and TB before cams though
whys that? i have a hallowed cat on the car, very little restriction on the exhaust end, and i think the intake on the car is pretty good flowing, would it make that much of a difference?
Dont forget to install a set of cam gears with the cams. then you have to spend the hours on the dyno fine tuning the gears to get the best gains.
technically, no he doesnt have to. however if you want the full potential from the cams you should.he doesn't have to. :shrug:
I got minimal gains by tuning the cam gears....but the powerband did change noticeably.:shrug:Dont forget to install a set of cam gears with the cams. then you have to spend the hours on the dyno fine tuning the gears to get the best gains.
yeah, but you had VCT so you were only able to tune 1 of the cams.I got minimal gains by tuning the cam gears....but the powerband did change noticeably.:shrug:
I have to agree 100%.loco im sure you can agree with me on this. VCT is hard to tune with and for. :shrug:
when i was going to attempt my small build. I was going to remove it entirely.
