ok, i didnt realize you had both cam gears. still though, you had VCT.
if he had adjustable cam gears on both cams. Then VCT would have needed to be removed.
The presence of VCT even more of a reason to get header, since you are trapped by exhaust cam timing versus PCM. Header will alleviate some of that, although I'm not a big fan of most of the "shorty" headers out there. They just don't work well. Primary tubes not long enough and really crappy entry angles at collector interface make me laugh when I see most of them. I used to hotrod a lot of different V-8 engines and even though header install can be problematic, it usually showed the biggest grins from end user when done. Header done proper can show huge increase in torque if engine wants it. If you gotta keep the converter in stock location, it will not be done right to make big power. Header needs to go in front of and under engine, converter further back and low my opinion. There just no way to get proper lengths otherwise. My view header to be done first mod, when all cylinders are being sucked down by each other properly with good tuned header, engine responds like a mild form of turbo without all the add on complexity. The VCT retard characteristic should even help that by increasing overlap. After header is other boltons, THEN you go internal engine. Hotter cams worthless if rest of motor not up to snuff for them.
