Blinkers doesnt work Emergency's do
Beans
Plymouth,MI
When i hit the indicator stalk i get nothing no clicks no lights, nothing but if i use the emergency's they work perfectly. every other light works
Thanks
:nonono:
stupid mystique
Check the fuse under the dash marked in the owners manual as Backuplights bet its blown change and all good but ..... does your vents work? if not they are also run through the same fuse.... hope this helps
check fuse for indicator lights, worse case scenario you need a new indicator stalk. Whop de doo :)
Anything you need I bet money bagged has, keep in touch I can probably bring it to you some time.
Spot on - thanks man, I was about to try and change both of the relays after my ac compressor seized yesterday.
