anyway, to come back on topic alittle here is an update on the clutchnet setup.
I have ~1k miles on the clutch now. I was as easy on it as I could be for ~ 500 miles. I have been pushing 12 psi for the last ~ 400 miles. This clutch grips. I haven't heard any odd noises or anythign recently. The one thing I noticed and I believe its just because of heat is sometimes it will grab lower to the floor. but as I recall in these situation I was in traffic or in a line of cars going into a car show. To keep things smooth I have been modulating the throttle alot while slipping the clutch. I would feather the clutch more the the engagement window is so small its kinda hard. as for the chatter, its getting better, but still there from time to time. I am going to be changing to filled roll restrictors to see if that helps at all. Otherwise it isn't to bad unless coming of the clutch to much with out enough rpm or forward movement. I haven't tried launching it at all but I feel confident the clutch will hold well.
overall I am happy with this clutch setup. I am confident/comfortable that the clutch will hold the power of the 3L turbo so that I can drive it how I want to and not have to worry. I would suggest checking out clutchnet if you looking for a new clutch.
