silverskoundrel
(Untitled)
Why would ford put these massive holes behind the SE or other emblems?
Close - "Knauberizing" - named after Robert Knauber, the first CEGer to do it.took the side door bump stops off. i think it's called de-knauberizing *shrugs*?
It's to encourage you to do the side marker modWhy would ford put these massive holes behind the SE or other emblems?
Sail Panel Removal/Install[/URL]
It's to encourage you to do the side marker mod[/URL]![]()
Thanks!! These cars are ment to be driven not garage kept anyway lolvery nice Superrob!!! I should take my SVT out of the garage sometime haha
There is a PDF attachment in that post- please try downloading it.I don't see any of the pics :\
My Innovate Motorsports LC-1 has been tripping out with an error code. Tried a complete re-cal today with no luck. Looks like it time for a new O2 sensor. Luckily it looks like it uses a standard Bosch O2 sensor available at Advanced Auto and is cheaper than ordering a new one.
The 'tour was starting a little slow yesterday. Battery tested bad replaced with a new bxt 40 r. Battery was 12yrs old if you can believe it. The stock battery died early from a trunk light that was stuck on. I cannot complain that's for sure. All sate now and charging perfect.
It works fine again except for the always present 1,2 bangshift.. "
