KAOS_3.0
Well, mexicans arent known for thier size. I know first hand. LOL
haha :blackeye:
Video.....................................
pwntbywombat said:we are beginning to think that it might be the ignition relay or something along those lines...
i dont even know what that it. i just had to order a reman axle today..the boot was ripped.
i dont even know what that it. i just had to order a reman axle today..the boot was ripped. we are beginning to think that it might be the ignition relay or something along those lines...because when you think about it, what else could it be? and i would have posted a video but its been raining every day ive had off and the contour is no longer privy to the garage now that winter is over. all i can say is that the starter clicks, not like it does when you have a dead battery, it sounds like its trying to engage the teeth on the flywheel but its bouncing off. like the gear inside the starter pops out, but then it just pops back. there isnt any spin after it pops out. its highly irritating.
the guys at pepboys tested it. the starter works, and no, it is not the original problem from the 2.5 cause this is the 3rd starter i've had since the 2.5. and a new axle was 40 bucks, so im not worried about it. not getting enough current could defiantly be a possibility. and how could it be hooked up wrong? the connections only go on ONE way. the power and signal wire are attached to each-other and only connect to the starter one way, that leaves only one other connection, the ground. so i dont know how it could be hooked up wrong.
fuz: it cant be a relay if the starter is clicking.
that doesnt make sense at all. how could it be an ignition relay if you hear the starter clicking and trying to engage? a bad relay would mean nothing happens at the starter. once the starter solenoid located on the starter "clicks", that means the relays have worked and sent power to the relays. If the gear doesnt mover out of the starter, than the starter is bad, if it does and the flywheel wont turn, then either the starter isnt getting enough amps or something is mechanically wrong with the engine/transmission.
use some logic. if the battery is charged, and the starter is hooked up correctly, and the engine turns by hand- all things you say are good- than it has to be the starter or the connections to the starter not giving you enough current.
here is a test, unbolt the starter and pull it off the tranny, touch it against the tranny or engine or something to ground it, and turn the key to see if it spins. if it does, its either the connections, the positive wire, or the starter itself- either not strong enough or the engine is too hard to turn.
