Newsvt
Well ill be interested to see how the car sits with my stock eo's and a mirko with just about the same set up as you!
The other thing I was wondering about was my sway bar endlink height. I really wasn't sure on where to set those. I may have just half a$$ed it when I set the pinch collar to where the sway bar endlink slid into it when there was no load on the car.
Good way to do this is put a jack under the control arm and raise it up to simulate ride height. Than adjust your collars so there close to equal position side to side. There will be no preloading of the sway bar than.
it appears you bought the BAT camber kit. That POS broke on me last Fall, allowing the strut to bang around in the strut tower
CSVT#49 said:I actually did not buy the BAT kit. I bought the Rock Auto camber kit, which I linked in the one post.
I took my splitter off for now, which gave me back about 2" worth of clearance. I'm rebuilding the front of my splitter and then designing my own skid plate for just the corners.
I may upgrade to 19" wheels so that I can gain a little more clearance. However I'm concerned about rubbing with such a large size wheel because I'm sure it will be a lot wider then my current 17x7... hell 18's are 18x8 and I know they rub. That is why I never bought the Focus RS wheels.
Really you should just be worried about overall tire diameter, the wheel size doesn't really matter. So if Reebs had some tall tires on those stock 16s they could've been considerably taller than your 17s.
You better have the splitter back on for this SaturdayIf you ever consider unloading those wheels let me know first
Sorry to disappoint Tony. You saw the pictures of the splitter repair...
Maybe I'll just get taller tires. I need new ones anyway.and the ones on there I believe are 215/45's
I'll probably end up getting 225/55 or 60's
i am a certified tech. i installed my own konis. i do all my own work. is their anything special i need to know when installing these? its a simple strut/spring r&r isn't it?
I'm not sure what the offset is like on those wheels but I'd imagine you'd be close to rubbing with something as wide as 225 and tall like that.
ultrarev shows the spring rates at 291 front 280 rear. im pretty sure they are a progressive spring but i could be wrong.did anyone find out the spring rate for this kit ? Def. want progressively wound..G.
Yea...
I just noticed that the noises I was hearing where due to the fact that the front springs were compressed way to far and the coils were hitting each other. I'm going to have to screw around with these some more in the front.
Usually to adjust coilovers you crank up the struts out of the base and then adjust your spring. The KSports I have do not thread out of the base in the front. Only the rear. So I have no adjustment without compressing the front springs...
So right now I have the base of the spring at 7" from the base of the strut with the pinch clamp for the end link at 2 1/2". I think to reduce the compression of the spring I'm going to have to set the springs to 5 1/2" from the base. However I don't know what that will do to my ride height.
