SicSE
01 water pump is the same design as the Contour, IIRC.what is the deal with the water pump location on a complete 01 aluminum oval UIM 3L?
00+ 3L IM's are all plastic.
The aluminum UIM's were on the 3L split ports from 96-99. They're only oval until just before the LIM, then they split.
Oval port intakes are plastic and have a different bolt pattern from LIM to UIM. So an oval LIM does not bolt up to a split UIM, and vice versa.
CKP is on the other side of the crank starting in 00. I also think I remember reading something about needing to extend the wiring for the knock sensor on certain swaps.from what I've seen, it mostly just takes splicing a EGR tube with the coupler, and rerouting the vac lines to all the right places.
What is VLIM?I see no point in using VLIM... my VLIM would bolt right up
Do you know what it is that's supposed to be so fragile? The crank didn't change at all up to 05. They revised the piston & rod combo for 99's and again for 00, but I don't know exactly what changes they made.a little question, say I find an 00-01 oval type with higher miles than a 97-98 split port, would the lower mile split port still be more fragile?
What is VLIM?
VLIM= variable length intake manifold, it's an acronym that goes hand in hand with IMRC (intake manifold runner control)
see, IMRC is only the secondaries and their actuation mechanism, IMRC goes underneath VLIM
I have no idea what you mean by CKP, could you clue me in?
also, I'd say fragile rods/pistons/wrist pins is a pretty bad thing to have, wouldn't you? or are you trying to tell me a rod out the side of my block is ok?
(sorry for the sarcasm, couldn't resist, I do appreciate the help, thanks)
I just finished my ported 3l swap and I'd have to say I spent ~2,000 by the time it's all said and done. That was with all the labor done by me and a torsen as well. You HAVE to replace your diff. I have a post about mine in the mtx forums. It didn't seem that bad, but by the time you buy all fluids, sealers, gaskets, misc. tools, ect... it really adds up. That is with an '03 20k mile engine for $450 from LKQ. I did not remove the heads either. Anyways, just trying to let you know what you're looking at moneywise. I can't imagine a straight 3l would be much cheaper.
I don't think he said anything relating to fragile parts being ok. All he said was that the pistons and rods were revised for 99 and then again for 00 and that the crank did not change until 05. I don't know where you go the idea that he said anything fragile was ok...:shrug:
PS: I think I may have jumped in his $h!z a little because I was slightly aggravated a guy trying to give me advice didn't even know what VLIM meant.
I don't see why you would get aggravated by a guy for not knowing what a VLIM is.:shrug: He did know what the CKP was and you had to ask him what it was.
Fyi, I think you might be the only one on this site using the terms "VILM" and "swirl port."
The Q about VLIM was MY attempt at sarcasm. I consider our intake dual length or path, if anything other than just an intake.(sorry for the sarcasm)
My Q about what is fragile is because you have to double-check and triple check your info. There's a LOT of bad info floating around that just gets blindly regurgitated without ever actually being proven or disproven.
in seven years on this site i've never once heard anyone call it a vlim.
just split port or oval port.
fwiw,in my time on the shoboards i've never heard that term either..so its not just here:shrug:it's a common term that carries across all engines with "twin runner" intakes.
maybe you guys don't use the standard acronyms, but that is the correct term for what you guys call "dual path" IM's.
starting to remind me of people wanting to think ATB's actually count as LSD's technically just because the manufacturer markets them that way to laymen.
