Contourgirl
New CEG'er
Ok, so my friend and I have been scratching our heads because of these 4 problems. So here goes. It is on a 1995 Ford Contour V6, 245,000 miles.
Problem #1, IDLE. When I am at a stop, my idle drops very low and gets close to dying.
What we have done so far: cleaned the upper intake (the back bank valve cover gaskets we replaced since oil was leaking into my spark plugs) so, we cleaned the upper intake and installed new gaskets. Along with new plugs and wires. And, my CEL came on as well, so we installed a new oxygen sensor on bank 2. So, it still continues. Any suggestions?
Problem #2, CLUNKING NOISE. There is a clunking noise, under my driver side (by my feet), when I am not pressing on the gas. When I am driving along, and let my foot off the gas (going anywhere between 30-55 mph) I can hear a clunk sound 3-4 times?
What we have done so far: replaced tie rod ends, replaced sway bar links, replaced control arms. All of these parts were bad to begin with, and we were replacing them anyway, so, it didn't fix the problem. Also, I just put another set of tires, brakes, and had my rotors turned.
Any ideas?
Problem #3, AIR BAG LIGHT. Yes, it is blinking. I thought there was a list of these codes somewhere on the contour website, but I couldn't find it. I have counted it and it never really gives me the same blinking code. Like it blinks 4 times or 3 times. Does anyone know where I can find the list of blinking air bag light? I just find this isssue really annoying if anything.
Problem #4, BACK UP LIGHTS. No, they stopped working. The bulbs are good, and the fuse is good. I heard we have to check the transmission range sensor to see if power is going into it (which, it should since the fuse is good, right) and to see if power is coming out of it, when the car is in reverse. Does this sound right? Has anyone else had this problem as well? Just curious.
So, that sums it up in a nut shell. After all the work to my car, I thought maybe 1 of the above (minus the backup lights)
So, thanks to anyone who has any suggestions/ideas!
Any ideas?
