teamSVTour
Koni's just came in and I want to make sure they are set on full soft when installed.  For whatever reason they did not come w/ any instructions.  Does the black tip on the struts screw off so that you can use the adjustment nob?  Some of the black pieces are screwed on more than others so it looks to me like that are all set on different stiffness. With the black pieces on there, the adjustment wheel appears to have no way of attaching to the strut.
Also if you look at the 1st pic, the left 2 struts have 2 plastic donuts where as the others do not. Is this normal or am I missing pieces?
Thanks
Thanks
