will 4 lug mustang rims fit our cars???
It also depends on how wide the wheel is... Don't think you can go bigger than 7.5"
so theres no point to 10in wide rims on a drag car right?I don't kow why you would want wider tires. :shrug:
The amount of tire contact with the road doesn't change with the tire width.
The tire contact patch is weight divided by air pressure. So a 5 inch wide tire and a 10 inch wide tire would have the same size patch, but a different shape. This is assuming they have the same tire pressure.
You can't doubt what I say all you want, but go look it up before you make comments.
Your logic is flawed. Drag cars' tires pressures are much lower because when the tires heats up from spinning on the asphalt, the air inside will expand inside the tire once the car starts getting traction.
