CSVT#49
Addicted CEG'er
Hmmm... is it possible there is an issue with the wiring to the front O2 sensor?? Lean condition is indicated by a low voltage, less then .45V... so you could have a short to ground or a cut wire on the front bank O2 sensor wiring. This is what is indicated by the P1151 code...
- Short to VPWR in the harness or HO2S
- Water in the harness connector
- Open/shorted HO2S circuit
- Corrosion or poor mating terminals and wiring
- Damaged HO2S
- Damaged PCM
