BK4293
I call BS, go get your car off Ebay and prove it beaner!!!!
ive had my stock zetec 5-spd up to 130 mph took me forever to get there but it made it.
It depends on some things. I had a superchip reprogrammed by KKM with the normal off the shelf superchip program. I made sure to ask if it would remove the speed limiter. They said yes and it worked. Not sure if they had to go in and make sure the speed limiter was off or not. I heard of other people with different ECU codes having trouble getting it removed.alot stuff is flying around in here. maybe the chips have gotten better but I had used chips in the past and junk them they did firm up the shifts in the atx but none could defeat the speed limiter. after doing my mods I finally went for a dyno tune to rewrite the whole factory program by a well known ford tuner in my area, i had to jump in on a dyno tune day when he was doing mustangs, and a turbo t-bird. he did alot to the motor, changed tourqe converter lockup, shift points etc, but had one hell of a time defeating the factory speed limiter, and told me he could see why off the shelfers couldn't do it, in fact he said he could 3 contours in a row and one of the 3 may not take right away, it took 2 times to get mine. you need a dyno tune or some tyoe of tuner but a plug in chip wont do it.
That's true (and I was running stock size tires at the time, doubt it would have done it on 17"s). But I know I had my car up to atleast 125. 3rd gear in the auto tops at 124 and I topped it out and from there the car definitely gained speed. It may have only been 126 or 128 but when the speedo topped out, it was still pulling but I stopped. I'm sure I was on a slight down hill and had a slight tail wind to help but it reached it nonetheless.Saying that your speedo read 130 or whatever means NOTHING.
