Pole120
Addicted CEG'er
i think im gonna get another set and have them coppered
OMFG fuggin HOT! :drool: :drool: :drool:
So bagged, how many hours do you have into some of those parts?
for the manifold using a grinder and a stepped sanding disc will make quick work of the sand casting. after that its just sanding out the little imperfections and marks. another option,if you have access to a sand or media blaster. will make esp. quick work of the valve covers.
The Mothers PowerBall Mini would make quick work of your final polishing step.
http://www.mothers.com/products/productcatalog/power_prod.html
http://www.autogeek.net/powerballmini.html
i think he meant when your done sanding and you need to use metal polish after sanding:shrug:
Im doing the samething to my gf's cougars car. Its a crap load of work, but def one of my winter projects.
Zetec can be polished. Thats a contour cover i have on my focus. Took a lot of work but came out great. Its no 100%alu. though. Its Magnesium and aluminum i believe so it shines but not as bright as aluminum. Used buffing pads on a bench grinder with 4 different compounds and wheels.
no..you need to polish them after sanding....trust me..it'll look much better.
