crewchiefpro Hard-core CEG'er Joined Feb 26, 2008 Messages 1,180 Location Citra, FL and Peoria, IL Dec 26, 2013 #41 The only way to know for sure is to install them. Make sure piston to valve clearance is double checked in both depth and radial. 4 mm is pretty high. Looks like more compression than 11 to 1.
CSVT#49 Addicted CEG'er Joined May 28, 2004 Messages 6,768 Location Andover, MN Dec 27, 2013 #42 I would agree that it looks a bit high. Definitely double, triple check your clearances. Sent from my ADR6425LVW using Tapatalk
H Heywood Hard-core CEG'er Joined Jan 24, 2006 Messages 1,422 Location Montreal Dec 29, 2013 #43 CSVT#49 said: I would agree that it looks a bit high. Definitely double, triple check your clearances. Sent from my ADR6425LVW using Tapatalk Click to expand... Honestly, I think it will be fine. The stock piston has small valve reliefs in it. The sides of the dome are matched to that.
