Irish Pride
Tonight i was on my way home and about half way home the heat cut out. It just started blowing cold air. As soon as this happened i looked at the temp guage and sure enough it was climbing up towards overheating. I immediatly turned off the engine and pulled over to the side of the road. I popped the hood and it wasnt boiling over and it had coolant in the resivoir. It doesnt leak any coolant and the temp guage has never fluctuated. The temp needle is always steady in the middle of the guage until this happened. I have done some reading on the forum and it sounds like the water pump might have gone bad but i'm not certain. Could this problem be caused by air in the system. I only ask this because i have noticed recently the past couple of weeks that if i park on an incline when i start the engine the radiator light will be lit up. After i drive for about a mile or so it will go off. It only comes on when parked on an incline. Just wondering if this might be related to what happened tonight. Any input will be greatly appreciated. Thanks
