alwayssideways
smooth design!
hmmmmmmmmmmmmm. I like that one. is that a cat even. . . ?
here's what I came up with, it might need to be tweeked down a bit for clearance issues, but I think it's almost equal length and it retains the U shape and the cat. I did two versions, one with a single highflow cat in a test pipe, the other with a big dual inlet cat like found on some V8's in a special "Y/test pipe".
also, a compact dual inlet single outlet muffler/resonator could be placed there if a CAT is not needed and you just wanted to run a turn down behind a front wheel. or heck, you could even run a pair of small resonators with a turn down behind each wheel and you'd have a very loud set of true duals...
I tried to keep within the silhouette of the brullen pipe to keep fitment somewhat realistic, but real measurements of available CATs/flex's/resonators would need to be done to know for sure
lemme know what you think...
I found pictures of the Brullen Y-Pipe but am having technical difficulties in uploading them from Photobucket. Bear with me. I'll eventually get it right.(Ah, 3rd time was the charm)
I actually don't like this design. the ends of the premade flex pipe bottle neck the flow ruining the whole design.
Looks almost as if it's a 1/4" difference.
Just after the Y meets in that larger section, it bottlenecks to go into the flex pipe.
No good!
for me anyway.
I think the upper drawing will be more cost effective of the two to build. The problem I see with either design is that the runner going to Bank #2 (radiator side) will dip down a bit too close to the pavement and be at significant risk of getting crushed or caught on something if you drive over a big bump or rather large pothole.
I found another picture of a Brullen Y-pipe that I will post in a separate message (it doesn't want to link into this reply for some reason).
Well, all I can say is that designed was proven to be successful in terms of sound quality (no drone or rasp) and on the dyno. Unfortunately, all the most important forum messages that discussed its performance cannot be accessed because the old archives can only search 30 pages into a thread; the group buy thread ran ~ 41 pages and the deliverys started at page 30. Some people did run into fitment issues but I don't know exactly what the issues were. My guess is that the pipe sometimes butted into the subframe on the right side or clashed with the power steering hydraulic hoses that run along the lower right side of the subframe. The Contour is a difficult car to design a great exhaust for to say the least.
There's a reason we refer to them as Wrongbendz....just sayin.
HA "wrongbendz"
well I just moved again so maybe i'll continue this.
problem is I am looking for a commuter: motorcycle, small pickup, civic crx, etc. lol
once that's acquired i'll finish the new y-pipe design.
