kidSVT
Hey all, my SVT is shaking from 55-65mph, and the mechanic says that the front right axel is bad.. where can I get this from? I was looking on Bill's teamford site, but I couldn't find anything... Thanks
~Andrew
~Andrew
~Andrew
Before going that route, have you had your tires recently rotated and balanced?
your vibration and noise could be a magnitude of different things in the suspension of the vehicle including the balance of your wheels and tires. but from my knowledge if it is making naoise it slow speeds or even when you turn i would says it is not the balancing of your wheels and tires. it is most likely a worn ball joint, wheel bearing, or what your mechanic said axel. all these parts are pretty easy to tell if they are shot by the movement of them just by jacking the vehicle up and jiggling around on the tire it should feel tight with no slop like feeling anywhere for the ball joints and wheel bearings to check the axel shafts just grab a hold of the shat and do the same things see if there is any loose slop at the knuckles which are located in the boots. you should be able to pin point your problem easily i hope this helps you out. i wish you the best of luck.
There isn't any noise when I drive the car.. just that semi-violent shake. I rotated the tires when I got home, still no difference. The rear tires that are now up front are in much better condition than the front ones were. . the wear bar is showing, but the wear isn't uneven. I dont' know if that bit of info would help you guys.
Is it possible to tell if a balance will fix the problem?? if you can't tell.. is it worth the money to get them balanced to see if it goes away? and lastly, is this constant shaking going to create another problem down the road?
Thanks alot for the advice guys.
get out of this Awsome NE forum. you no longer belong!!! haha jk
Do this, if you think its the axle:
Lift and support the front of the car (always use jackstands) and rotate the tires by hand. Make sure the trans is in neutral! If the wheels spin and then almost seem to tighten and then shake weird, you have a bad CV. That's how I diagnosed my failed CV, of course it also clicked on hard right turns (failed CV on right side).
