Barge
Well since I posted it in rogers thread i figured i might as well start my own so i can be one of the cool people.
The graph has 3 runs on it while I was playing with some tuning. I also has boost pressure, torque, and hp.
The 2nd major line from the top is 318 if you can't read it.
The torque and boost pretty much look the same which is what you'd expect. The boost pressure is the smoother one.
Since this i have discovered that the calibration they gave me with the map sensor for my boost controller pretty much stunk which is why the boost dropped off so bad... although i can really only run 16ish up to about 6k anyway.
Best pull of the day was 307tq, 223hp.
HP took a beating due to the upper RPM boost issue.
