Tourige
CEG's Resident Jackass
I believe that spinning your tires is a different result for many of us. One big difference is the diff. (lsd, atb, open.) A lsd will spin more than an atb or an open diff. If you want to burn out, pull the e-brake (if your set-up is locked rears) and dump the clutch at any rpms you will blow some smoke, on the right pavement. To get more smoke have a buddy dump some bleach on the tires as they rotate.
Thats always a good idea.. walking near a car doing a burnout..:help:
Put some bleach on the ground and drive into it if you feel like wasting the tires.
